  • 1994 - 1995 Specific Tech
Upper and lower control arms?
  • Thread starter Thread starter moneypit94
  • Start date Start date May 16, 2004
moneypit94
1,723
Macomb, IL
May 16, 2004
  • May 16, 2004
After going to the track with an easy 11 sec powered car and only going low 12's im looking to start upgrading my suspension.
On ebay i found upper and lower control arms for fairly cheap
What should i be looking for or looking out for? I want to get rid of my quad shocks. When i do the swap i plan on putting either adjustable shocks and struts on too or a set of lake wood 50/50's and either 90/10's or 70/30's
Is there any good brands out there that are somewhat inexpencive?
94TURBO5 O
2,509
VA
May 16, 2004
  • May 16, 2004
If you want superior performance and longevity get the good stuff IMO.
I would go MM ajustables or Hotchkis.
swingline
1,252
TCB - Taking Care of Business
May 16, 2004
  • May 16, 2004
www.jdsperformance.com has a set up upper/lower's for pretty cheap.
Joes95GT
3,132
Delaware
May 16, 2004
  • May 16, 2004
With any suspension part, for any car, for any application, you get what you pay for. MM is the most expensive for a reason. Most of the moderately priced CAs are about the same in quality, and honestly, anything is better than stock.
Joe
95BLBLVert
486
Lake Wylie, SC
May 16, 2004
  • May 16, 2004
Metco Motorsports makes incredible upper and lower control arms. Quality should not be sacrificed here. MM does make quality products but I prefer Metco. Their lowers are billet aluminum and lighter than many others on the market. You want to keep the unsprung weight to a minimum while at the same time choosing arms that will eliminate bind. The uppers are adjustable for pinion angle and very strong. Price in about the same as MM.
moneypit94
1,723
Macomb, IL
May 16, 2004
  • May 16, 2004
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2476625383
I put a bid on these lowers... Now i need to get some shocks and uppers... gotta be better then stock like joe said.
1968 coupe global west upper control arm template
  • Butchd88
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 12, 2026
Butchd88
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
Which Lakewood Front Struts Would Work the Best?
  • 93gtmustang
  • Nov 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2025
Ethereal_Zer0
E
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
