Upper Control Arms: what do they do?
  • Thread starter Thread starter fiveoho
  • Start date Start date Mar 23, 2006
fiveoho
1,958
TN
Mar 23, 2006
  • Mar 23, 2006
sorry for the dumb question but i won't know till i ask, right?
what exactly do upper control arms do? I'm looking at a set of UPRs. just wondering.
can you run just the uppers or do you have to have the lower control arms to go with it?
thanks
Fox_84
143
  • Mar 23, 2006
You can run just the uppers, but there is actually less benefit from the uppers than from the lowers. Most of the time if you are just gonna replace one (uppers or lowers) most people choose to replace the lowers. I would most definitely replace the lowers and depending on what you are doing with the car and how much power you plan to put down, you could replace both. Again, as far as what they do, that depends on which ones you buy and what you are wanting to do with them. The main benefit is there is little to no flex with a good set of aftermarkets vs. the factory that flexes like crazy. They will just do their job better which is keep the rearend locked in position and transfer the power to the tires instead of flexing throughout the rearend. Maximum Motorsports sales several different styles and makes a really good set. There are many out there just read up on them and get the ones that match to what you plan to do with the car.
fiveoho
1,958
TN
Mar 23, 2006
  • Mar 23, 2006
preciate it man. i found some UPRs for $50 , uppers only.
so really to benefit more, i would need the lowers or the lowers and the uppers. do these stop tire spin? better launches? i guess what im asking: i plan on making around 300 rwhp. i want to be able to light em up if i want, will the control arms stop that?
also, is just the ride better with aftermarkets? cornering any better?
thanks again
rd
3,316
63
109
Ocean Springs MS
Mar 23, 2006
  • Mar 23, 2006
I agree that if I was going to change just one set, I would go with lowers first. If you look at the car in a plan view, the uppers are angled outward front to back, and serve as the transverse locators for the axle.
Under acceleration, they are in tension.
Having stronger ones never hurts, and will help control the monkey motion that causes wheelhop. Having adjustable length uppers will let you set pinion angle accurately.
Stiffer lowers, and or a lift bar style lower would be a more direct help to wheel hop and launch traction. Imho.
That said, I have boxed lowers and uppers.
fiveoho
1,958
TN
Mar 23, 2006
  • Mar 23, 2006
are they worth the $$?
noticeable difference?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 23, 2006
  • Mar 23, 2006
Boxing them is a neat way to save some $$$. How well do you think it works? Do you have any comparison data on before and after?
Fox_84
143
  • Mar 24, 2006
Man to be quite honest, boxing your factory control arms will have to add some strength but I would guess still far more flex than control arms designed to take the abuse. I have several parts from MM on my car and I love every one of them. Granted they are expensive, but I feel worth it.
fiveoho
1,958
TN
Mar 24, 2006
  • Mar 24, 2006
preciate it man-
something else i could consider i guess.
ive heard mm stuff is top notch
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Mar 24, 2006
  • Mar 24, 2006
Boxing should add at least 10 - 15 % stiffness to the components. You are basically taking a C-channel and making it into a box. I will be boxing all of my stock components when it's time to focus on the suspension.
The biggest bennefit when changing out the control arms is that you get new bushings. Stiffer bushings help control the motion between the links and this is what really helps. Of course there are drag racing parts like the Mega Bites / adjustable links, etc and those help people that like to go fast in a straigh line but I prefer to drive around corners.
There are a lot of comprimises that went into the design of the Fox body rear suspension. Since the uppers are used to locate the axle cross car and fore/aft, the bushings get a lot of abuse. Under hard driving around corners the axle can actually move up to 2" (rear steering.) A panhard rod / torque arm setup can correct these issues...
Anyone notice that a Semi truck doesn't have boxed frames? That is becuase the boxes would be so strong at resisting flex, that they would crack and break with all of the torque that those motors produce... who said flexable metal is bad?
Just my $0.02
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
Fox Traction control
  • Sparky714
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sunday at 9:49 AM
nicholase
