For once the search function failed me, I could not find a thread that addresses this issue (there probably is, but I was retarded and could not find it).
One of the lines that runs out of the back of the upper intake goes to the fuel pressure regulator. However, the new adjustable regulator I got does not have a spout for a line to come out of it. Should I just plug the line then (I can do this easily by just putting it over where I adjust the regulator), or is this a problem? Also, I noticed the stock intake has a spout on the front of the intake that runs to that little black box thing on the inside of the front passenger fender, and the new intake does not have any spouts on the front. Is it OK to plug this line as well?
Otherwise, the rest of the hoses on the intake switched over nicely, but I have yet to put the throttle body on, so we will see how those hoses and plugs go.....
For reference, I am going to be using the "cobra" intake, and I was using the stock intake before.
Furthermore, can anyone suggest a way for me to hold in the mass air meter? The stock one had a bracket on it I used to bolt it into the side of the fenderwell, but the new one does not, and it would be nice if I did not have a tube hanging and flopping around, but nicely secured instead. I imagine I could fab up something, but perhaps someone here has some advice to make something that might even be halfway decent looking.
