  • 1994 - 1995 Specific Tech
Upper intake problem
  • Thread starter Thread starter CManT1914
  • Start date Start date Jul 10, 2005
CManT1914
3,172
Killeen, Texas
Jul 10, 2005
  • Jul 10, 2005
As I figured, the upper intake does not clear the valve covers. I figure I have 2 options:
1) Grind down the EGR casting because I now longer have EGR anyway.
2) Put a 1" spacer between the upper/lower plenum.
The only problem is I have my hood off and I don't know if my upper will clear it with the 1" spacer. I can get a 3/8" spacer for free, it just might be this afternoon before I can get it. Will the 1" work? Or will I need a 3/8"? Or how hard is it to grind down the EGR casting? Thanks guys!
194stang
148
  • Jul 10, 2005
I just ground down the bottom of the EGR and the vacuum fitting on the drivers side. I have a cobra intake and fox covers of that helps ya any. Good Luck
4Jenna
4,326
AZ
Jul 11, 2005
  • Jul 11, 2005
They make EGR delete plates for like 20$
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 11, 2005
  • Jul 11, 2005
i made my own plate out of some aluminum i had in my garage...
traced the EGR gasket onto the ALUM
cut it out, drilled holes for bolts
went around edges with RTV
stuck it on and bolted it in place
done
CManT1914
3,172
Killeen, Texas
Jul 11, 2005
  • Jul 11, 2005
I just ground off the EGR casting and got a 3/8" spacer from a friend. Problem solved.
SOLD Ported GT40 tubular upper and lower
  • Kid wita 5oh
  • Nov 11, 2025
  • Engine and Power Adder
Engine and Power Adder Nov 11, 2025
Kid wita 5oh
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
Engine and Power Adder Aug 19, 2026
Habu135
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
