Upper Intake That Doesn't Go Over Valve Cover??
I don't know any that don't go over it over than the box style intakes, and they are for high rpm strokers or supercharged engines. Not something your really want to do for a car that will see some low rpm use on the street.
Are you having clearance issues? A spacer could help that.
edelbrock victor 5.0 or Trick Flow Box R, but both of those intakes are pretty serious, and its gonna take a well built motor to keep up with them. Also stock fuel rails will not work with the Box R, and it definitly wont clear a stock hood
the easiest way i could see making it fit is a spacer between the upper and lower manifolds. you might be able to get away with a 3/8 in spacer. if you need more clearance 1 in would be the way to go. since you have a cervinis cowl hood the height of the intake shouldnt be an issue.
there is also the efi spyder from probe industries , might need a supercharger or turbo for that one to , or another option would be to get a duel plain intake an have a shop machine it for the fuel injectors an give wilson maifold a call an have the shiop you an elbow to mount on top
Probably make more power up top, less down low.
I'd rather use the edelbrock victor if it meets your fitment needs, the runners may be short, but at least it has runners.
