F ford Gt New Member Feb 4, 2006 17 0 0 Washington PA Mar 12, 2006 #1 Mar 12, 2006 #1 In foot pounds, what is the torque specs on a 98 cobra upper plenun?
Dan_Soprano 15 Year Member May 7, 2003 7,410 54 129 Jacksonville, FL Mar 12, 2006 #2 Mar 12, 2006 #2 ford Gt said: In foot pounds, what is the torque specs on a 98 cobra upper plenun? Click to expand... i think it is 14 ft/lbs, but I am not sure.........may be less..........
F ford Gt New Member Feb 4, 2006 17 0 0 Washington PA Mar 12, 2006 #3 Mar 12, 2006 #3 Dan_Soprano said: i think it is 14 ft/lbs, but I am not sure.........may be less.......... Click to expand... That sounds about right, I already did this once, I remember the newton pounds that my chilton lists, but I estamated last time, and I forget what I came up with. Thanks.
wythors Get off my lawn!!! Founding Member May 17, 2000 2,277 35 69 C Addle Mar 12, 2006 #4 Mar 12, 2006 #4 According to my Ford factory manual, it's 71-106 lb-in. According to a quick Google, 1 inch pounds force = 0.0833333333 foot pounds. If you don't have an inch pound torque wrench, I'd highly recommend getting one for working on DOHC engine.
missouri_guy197 New Member Aug 31, 2002 1,441 1 0 St. Louis, MO Mar 13, 2006 #5 Mar 13, 2006 #5 wythors said: According to my Ford factory manual, it's 71-106 lb-in. According to a quick Google, 1 inch pounds force = 0.0833333333 foot pounds. If you don't have an inch pound torque wrench, I'd highly recommend getting one for working on DOHC engine. Click to expand... This is correct... or in ft-lbs that is ~6-9ft-lbs
F ford Gt New Member Feb 4, 2006 17 0 0 Washington PA Mar 13, 2006 #6 Mar 13, 2006 #6 missouri_guy197 said: This is correct... or in ft-lbs that is ~6-9ft-lbs Click to expand... Thanks.
