  • 1994 - 1995 Specific Tech
upr coilover kit
  • Thread starter Thread starter paxton86
  • Start date Start date Apr 30, 2006
P
paxton86
38
  • Apr 30, 2006
the kits been sitting in my house for about a month now, and i tried installing it a few weeks ago, but im not sure if i use all of the stock rubber peices from the strut tower mount or not. i put it all on, but it didnt look right, like it was too tall, and the nut on top didnt want to tighten more than a quarter of the way of what it should.
i tried to put it all together before i put it in the strut tower, should i be doing it a different way? do i use all the rubber peices or are some unused?
95snoozer
2,572
RCR
Apr 30, 2006
  • Apr 30, 2006
use a rubber bump stop
on teh strut inside the spring, so the shock doesnt bottom out which it will if you have stock struts and drag springs
for the top, use everything, if you haev stock CC plates, take that metal cylindrical piece and cut it down to slide it badck inside the top rubber bushing. Then you can tighten it all the way down.
95snoozer
2,572
RCR
Apr 30, 2006
  • Apr 30, 2006
It wil help to get after market CC plates with a spherical bushing in the top
otherwise along with the clanking, the coils will twist up and when they break free and untwist you will hear duuoing!, it gets very annoying. I found my coilovers very very annoying for a daily driver. Thats why i dont even want a tubular K member anymore unless i can run a standard spring.
the coilovers also do not clear my wheels and tires by more than a few MMs and they rub in turns, With the skinnies it was great and i dailied on them for a year. the drag springs handles BETTER than stock. I had 14 inch 175s
LXSTASY
932
Long Island, NY
Aug 13, 2006
  • Aug 13, 2006
How wide were the tires you were running that were rubbing?
WhiteDevil
2,717
San Diego
Aug 13, 2006
  • Aug 13, 2006
Yeah my friend had rubbing problems after he got 17x9s up front too.
PA Racing makes a spring perch kit on their K. Thats the one i got.
Suspension UPR Coilover sleeve dosent drop down over strut
  • Creomod
  • May 25, 2025
Fox 5.0 Mustang Tech May 28, 2025
RaggedGT
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
