  • 1994 - 1995 Specific Tech
Used gears??
  • Thread starter Thread starter drewzx3
  • Start date Start date May 31, 2007
D
drewzx3
411
Louisiana
May 31, 2007
  • May 31, 2007
I been thinking about getting some gears and I have seen some used gears for good prices. I was wondering if anyone has ever bought used gears and had any problems with them. Also what could you look for to tell if there in good shape?
bchilt
23
Beaverton
May 31, 2007
  • May 31, 2007
I've always been advised to avoid used gears. The wear pattern from the previous car can cause the gears to howl in your car. It's a good question and I'm curious to see some more responses.
bill302
2,131
alabama,gadsden
May 31, 2007
  • May 31, 2007
no problems with used gears here, just ensure you by ford namebrand gears only. as long as the gears are not cracked or chipped their should be no problems gears howl because there installed wrong.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 31, 2007
  • May 31, 2007
Ive always heard to stay away from them too.
I got my gears, install kit, trac loc rebuilt for like $330 from www.buyfordracing.com if it helps.
R
red95gtconvert
382
Ponca city, OK
May 31, 2007
  • May 31, 2007
I installed a set of gears in our Mustang that I ran for a couple of years in my F150 and have no howling or whining with them, they only had about 10k miles on them and they are Ford gears.
reddy351
560
12
38
Columbus, Ohio
May 31, 2007
  • May 31, 2007
One way to tell if gears are good is to run your finger across the leading edge of one of the teeth. If it "cuts" you, they're no good. If it is "rounded-off" they are prolly ok. Not a hard/fast rule, but good to know if you are buying from a JY or sawp meet.
FYI--Some Explorer Sport Trac's (ugly as they are!) came with 4.10 gears. So, if you see one in a JY, check the tag on the diff cover.
F
Fopar
178
San Marcos, CA
Jun 1, 2007
  • Jun 1, 2007
I wouldn't do it, anyone that doesn't have a whine after is just plain lucky, it's almost impossible to setup used gears in a different case perfectly.
Venom351R
4,548
41
98
MAINE
Jun 1, 2007
  • Jun 1, 2007
I installed used gears before and did not have any problems. It all comes down to how well they were installed before and the wear pattern on them. Gears can be bought pretty cheap so unless you find some used ones for dirt cheap then Id just buy new ones.
94-302-vert
1,947
NE CT
Jun 1, 2007
  • Jun 1, 2007
I basically put in used gears... the guy that did my install didn't get the right torque on the pinion bearings and they got shot and I drove about a 1k miles on them, had him rebuild it, still not right, another 1k miles later (when the sound was getting bad again) my bud and I got the right torque on the pinion bearings and in the last 28k miles the sound has gotten better....
So while it may seem worth it to save the $$ I would still buy new gears... I went 20k miles not trusting my rear end due to the noise/vibration....
If you need to save $ I think the 4.10s are cheaper than 3.73s....
GTJake
3,049
Ann Arbor, MI
Jun 1, 2007
#10
  • Jun 1, 2007
  • #10
Just gotta be smart when purchasing used gears. I've been running them for 4 years now with no probs.
Jake
SublimeRT
230
Clarksville, TN
Jun 1, 2007
#11
  • Jun 1, 2007
  • #11
I agree. It's either a hit or miss sorta thing.
95CobraMike
1,046
Lima OH
Jun 1, 2007
#12
  • Jun 1, 2007
  • #12
i had used gears with no problems... just like stated above make sure to look at the wear patterns and make sure everything doesnt look like its been rubbed the wrong way. if it passes that test, make sure whoever installs them knows what they are doing or they will whine
D
drewzx3
411
Louisiana
Jun 1, 2007
#13
  • Jun 1, 2007
  • #13
I found a set and the guy says they were only used for 100 miles. I know the guys that are putting them in do good work because they put the gears in my brothers 4x4 truck in the front and back and he hasnt had any problems plus that pretty much all they do in there shop. I cant decide if I want to get them that I found though.
5.0 from 95
738
Emory, TX
Jun 1, 2007
#14
  • Jun 1, 2007
  • #14
Mine are Ford and had about 2k miles on them when they were installed in my car. I have no whine for about 2 years now. Installer is the biggest part with good used gears. Make sure they are in good shape.
Paul
5.0 from 95
738
Emory, TX
Jun 1, 2007
#15
  • Jun 1, 2007
  • #15
Sorry for this post but I had to get off of the #666 post.
Paul
9
94v6GT
141
#16
  • Jun 1, 2007
  • #16
since most of the $ is install labor, how much are you really saving? im not sure if the cost savings would out weigh the risk of having whine/howl or having to get more.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
