Used style bar install
  • Thread starter Thread starter billison
  • Start date Start date Dec 26, 2012
billison
I like tinted tail
2,607
1,094
184
stl
Dec 26, 2012
  • Dec 26, 2012
I found a used style bar for my 92 with no hardware. Any ideas what's needed to install it? I don't wanna get stuck needing custom parts..
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 26, 2012
  • Dec 26, 2012
You can go to cdc and download the instructions and templates. There are different holes for 90 and up. You need to remove the rear seat and inside 1/4 panels after you've drilled the holes for the bar. I've installed a few and you should fab up some brackets to mount the bar to. If you just bolt it in, you will notice it flops around. Is it a styling or a light bar? If it's a light bar you also need to hook up the light to the 3rd brake light wiring.
billison
I like tinted tail
2,607
1,094
184
stl
Dec 26, 2012
  • Dec 26, 2012
it's just a styling bar. as far as where it bolts up, i'm figuring it out based on some instructions i've seen online, it's just a matter of removing the seat, the 1/4 panels, removing 2 bolts on both sides and installing it with longer bolts I assume right?
billison
I like tinted tail
2,607
1,094
184
stl
Dec 26, 2012
  • Dec 26, 2012
i just read the cdc instructions, they are the best ones i've seen. Install seems to be pretty easy. the only hard part will be cutting the holes without the template.
G
Style Bar
  • gray owl
  • May 28, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 30, 2026
I Bleed Ford Blue
R
Suspension Bushings for SN95 Steering Rack with UPR K Member
  • Riley Barth
  • Jun 23, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
427stang
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
