Used style bar install
billison
I like tinted tail
2,607
1,094
184
stl
I found a used style bar for my 92 with no hardware. Any ideas what's needed to install it? I don't wanna get stuck needing custom parts..
You can go to cdc and download the instructions and templates. There are different holes for 90 and up. You need to remove the rear seat and inside 1/4 panels after you've drilled the holes for the bar. I've installed a few and you should fab up some brackets to mount the bar to. If you just bolt it in, you will notice it flops around. Is it a styling or a light bar? If it's a light bar you also need to hook up the light to the 3rd brake light wiring.
it's just a styling bar. as far as where it bolts up, i'm figuring it out based on some instructions i've seen online, it's just a matter of removing the seat, the 1/4 panels, removing 2 bolts on both sides and installing it with longer bolts I assume right?
i just read the cdc instructions, they are the best ones i've seen. Install seems to be pretty easy. the only hard part will be cutting the holes without the template.
