well guys im gonna work on fixing that leak with my UPR X. im gonna put RTV on all the connections, and in the O2 sensor threads. any ways, i have to get the car off the ground obviously. well i got ramps for the front. on my GT, i just drove up the ramps and used a floor jack in the middle of the rear axle under the differential housing, and put blocks under the rear tires.... well, im not sure if it would be safe doing that with my IRS cobra. can i still jack it up like that?? or is there some other way i need to do it??? hopefully i explained this correctly. thanks guys!!
on blowing out a diffseal by jacking you car up by the pumpkin on a solid axle. If anything putting jack stands on the axle tubes is would be worse IMO.
