Using LOCTITE to threadlock shiftknob?
  • Thread starter Thread starter PonyBoy90
  • Start date Start date Jun 1, 2004
P
PonyBoy90
555
Toronto
Jun 1, 2004
  • Jun 1, 2004
I just recently installed a Steeda Tri-ax shifter into my tranny. Along with the tri-ax, I purchased the Steeda Insulated Shiftknob. It simply just screws on to the shift handle. There is NO tightening screw (alan screw) on the base of the knob to tighten the knob to the handle and prevent it from loosening. I'm finding every now and then after prolonged use, the shiftknob does tend to loosen/come undone and I have to retighten it. I'm afraid that too much of this will end up stripping the plastic inner thread of the shiftknob and I'll have to buy a new one ($35).
I'm really tempted to put a little bit of "LOCTITE 242" threadlock glue along the lower portion of the thread on the shifthandle and then screwing the knob back onto the handle hoping the glue will aid in the prevention of the knob from continually loosening, at the same time, the LOCTITE I'm going to use is "breakable" meaning if I ever have to take the knob off, with some effort I can break the seal and unscrew the knob no problem.
LOCTITE has a warning that it's not good for thermoplastics, however, the knob threaded insulator is delrin plastic and a tech from LOCTITE said it's ok and won't eat/dissolve the delrin.
Should I use it????????????????????????????
Thanks
SuperStang83
1,693
Boyertown, Pa
Jun 1, 2004
  • Jun 1, 2004
If the tech says it is okay then I can't really see it hurting! I guess it is better than your handle randomly coming off.
Jakob
50Dreamer
688
17
38
CT
Jun 1, 2004
  • Jun 1, 2004
Go for it if they say its ok...BTW I used gasket sealer because of the thickness of it and never had a problem.
P
PonyBoy90
555
Toronto
Jun 2, 2004
  • Jun 2, 2004
Thanks guys
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Taurus Fan And Fal 33054 Install On A Fox
  • No.11
  • Oct 4, 2016
5K
Fox 5.0 Mustang Tech Oct 11, 2016
MFE92
How To: Complete Your Auto To Manual Conversion W/factory Tranny Tunnel "hat" ***pics***
  • 94GTCoupe
  • Jul 7, 2013
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 7, 2013
94GTCoupe
Install '87-'95 Heads, Cam, Intake Install
  • 5spd GT
  • Sep 25, 2013
  • Resource Discussion Forum
12K
Resource Discussion Forum Sep 26, 2013
Gearbanger 101
M90 root blower how to info
  • 1987LXragtop
  • Jan 7, 2011
  • SN95 V6 Mustang Tech
9K
SN95 V6 Mustang Tech Jan 7, 2011
1987LXragtop
