  • 2.3L (N/A & Turbo) Tech
V6 driveshaft?
  • Thread starter Thread starter stykthyn
  • Start date Start date Jul 29, 2008
stykthyn
5,232
2,652
223
gainesville
Jul 29, 2008
  • Jul 29, 2008
I have a friend with a driveshaft from a 94 3.8 with a T5. he says it's the same length as the 4 cyl t5.I dont have a t5 driveshaft to measure it against. will this work behind a 4cyl T5?
stykthyn
5,232
2,652
223
gainesville
Jul 29, 2008
  • Jul 29, 2008
ok, if no one knows, does anyone have the measurements for the 4 banger DS?
stykthyn
5,232
2,652
223
gainesville
Oct 23, 2008
  • Oct 23, 2008
fast forward two months and seemingly nobody knew the answer or cared to give an answer. for anyone that was curious the V6 driveshaft worked perfectly for the swap.
Red
4,517
Rahway, NJ
Oct 23, 2008
  • Oct 23, 2008
good info to have.
J
Jimmy2Times
63
Atlanta, GA
Oct 24, 2008
  • Oct 24, 2008
Thanks for the info stykthyn. Does the V6 driveshaft have that balancing collar/weight around the yoke that slides into the T5 tailshaft housing? My 4-cyl shaft has this and I'm wondering if it's necessary or if I'd be ok swapping in a shaft without it?
stykthyn
5,232
2,652
223
gainesville
Oct 24, 2008
  • Oct 24, 2008
no, it was not there. also the SN driveshaft is a little fatter. the clearance for the exhaust was tight. if you have a lowered ride you may have to doublechexck to see if you have enough space.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
F
T5 transmission questions
  • Forddestroyer96
  • Aug 27, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 27, 2025
Forddestroyer96
F
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
88 Foxbody 5.0 Driveshaft Issue! Need Help
  • James Hood
  • May 1, 2025
Fox 5.0 Mustang Tech May 1, 2025
AeroCoupe
