vac lines
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
was just wondering if any one could help me identify what the lines that come off the vacume tree on the fire wall and what ones i dont need if i got rid of the a/c.
The short answer is none.
The diagram that JR posted up, does identify vac lines as A/C the way Ford did, but they can be more accurately described as Climate Control.
That vaccum source is what lets you choose between defrost, vent, and heat outlets when your blower is on. If you were to remove that vac, your air/heat would only blow out the defrost.
