M Must5a0angGt86 Founding Member Mar 21, 2002 178 0 0 CT Apr 21, 2006 #1 Apr 21, 2006 #1 I seem to be missing the Vaccum line that runs to my EGR valve. I was wondering where the other end is supposed to be plugged into? thanks
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle Apr 21, 2006 #2 Apr 21, 2006 #2 Any open supply from the intake, or the vac dist block should work well. jason
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Apr 21, 2006 #3 Apr 21, 2006 #3 The EGR valve gets its vacuum from the EVR. The EGR cant get vac at idle, which would occur if using manifold vac.
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,813 234 Dublin GA Apr 21, 2006 #4 Apr 21, 2006 #4 See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ http://www.veryuseful.com/mustang/tech/engine/images/IgnitionSwitchWiring.gif http://www.veryuseful.com/mustang/tech/engine/images/fuel-alt-links-ign-ac.gif http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif Diagram courtesy of Tmoss & Stang&2birds Attachments mustangFoxFordVacuumDiagram.webp 37.3 KB · Views: 118
xporter Member Apr 9, 2002 34 2 6 Florida Apr 22, 2006 #5 Apr 22, 2006 #5 There should be a vacuum connector on the passenger side of the engine bay with 4 vacuum lines. It goes to the green line on that connector.
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle Apr 22, 2006 #6 Apr 22, 2006 #6 HISSIN50 said: The EGR valve gets its vacuum from the EVR. The EGR cant get vac at idle, which would occur if using manifold vac. Click to expand... I bet that won't be the last time I screw up either.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Apr 22, 2006 #7 Apr 22, 2006 #7 vristang said: I bet that won't be the last time I screw up either. Click to expand... I actually thought you misread the question and thought he was already talkin about the EVR. No bigs.
