Vacuum Advance Problem
  • Thread starter Thread starter healeymanjim
  • Start date Start date Dec 8, 2015
H
healeymanjim
  • Dec 8, 2015
daughter has a 66 coupe with 289 edelbrock 4 barrel. discovered that vacuum advance had a hole in diaphragm so replaced it. now the engine starts fine like before, but as soon as accelerator is increased, the engine starts to buck and surge. disconnected and plugged tube coming from passenger side of carb and it seems to run fine. not sure whether carb, distributor or timing problem. any help appreciated.
tos
896
68
59
Cincinnati Ohio
Dec 10, 2015
  • Dec 10, 2015
Sounds like its advancing way to early or easily. Check your springs? Make sure your wires aren't getting pinched when advancing. You can operate that advance with the dist cap off by putting a hose on the dist port and sucking on it to see whats going on. Is it backfiring thru the carb
Edster
500
League City, Texas
Feb 4, 2016
  • Feb 4, 2016
Passenger side is ported vacuum, so when the throttle is opened it puts vacuum to the distributor. Ser the timing with the hose disconnected at the minimum spec per manual and start from there.
Sent from my C6606 using Tapatalk
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Feb 11, 2016
  • Feb 11, 2016
Some aftermarket vac canisters are adjustable. Check your base timing like above, then see what the total mechanical advance at rpm is from there. If the canister has been bad long enough, it could be tuned for advance without vac. You'll want it for highway and cruising. So third, make sure what the total advance is with the canister plugged into the right port. If an Allen wrench in the tube (like on an HEI) does not do it, they are sometimes marked with how many degrees and can be swapped. Or a blocking plate allowing partial advance can work.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
G
Autolite 1100 idles well, bogs when accelerating 1966 200
  • Green headache
  • Oct 5, 2024
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2024
Green headache
G
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
