  • SN95 4.6L Mustang Tech
Vacuum drop after PI Swap
  • Thread starter Thread starter SFC.Kill
  • Start date Start date Apr 20, 2009
SFC.Kill
55
Parker Ford, PA
Apr 20, 2009
  • Apr 20, 2009
My gauge was reading 12hg at idle before Full PI Swap. Now it is reading 6hg is that because of the increased compression ratio? I noticed to after swap my car idles at 1000, was at 700 before swap do I got a problem somewhere. Pulled off IAC connector and no change in idle. I drilled and tapped the PI intake so I have both coolant sensors. Also my idle hangs too. Might have to do IAC mod.
the98stang
2,408
Clovis, CA
Apr 20, 2009
  • Apr 20, 2009
It's pulling in air somewhere from a vacuum leak. Use a butane torch to find the leak (butane will cause a rise in RPM once the leak it found). Check all vacuum hoses, especially the ones you removed for the swap.
bhuff30
6,037
35
129
Olathe KS
Apr 20, 2009
  • Apr 20, 2009
Yup, definately a vacuum leak somewhere. Even 12" Hg seems a bit low. Another trick is to use starter fluid and spray in various places you suspect. If the idle speed increases, you found the leak.
SFC.Kill
55
Parker Ford, PA
Apr 20, 2009
  • Apr 20, 2009
Cool, will check it out.
R
Red04GT
10
Gardner, KS
Apr 20, 2009
  • Apr 20, 2009
i do not suggest using a TORCH to check for vacuum leaks. Plastic intake......propane is an option but the safest way is to check the car is with a smoke machine. but i know most people dont have access to one.
jivepepper
776
Under a Sombrero. in WV.
Apr 21, 2009
  • Apr 21, 2009
There's a vacuum leak some where.
SFC.Kill
55
Parker Ford, PA
Apr 21, 2009
  • Apr 21, 2009
You don't light the touch, just turn the propane on. Wherever the vacuum leak is it will suck in the propane increasing the idle. I hope you were only kidding.
squeak93
2,348
417
164
Joplin, Missouri
Apr 21, 2009
  • Apr 21, 2009
+1 on the major vac leak. Souds like with your coolant leak and vac leak, your for sure going to be pulling the lower intake.
J
justinschmidt1
349
  • Apr 21, 2009
Im pretty sure my car is usually pulling about 20 hg vacuum at idle
Skud
493
Saskatchewan
Apr 21, 2009
#10
  • Apr 21, 2009
  • #10
I pull 15" and that's with MPH blower cams..
I think 20+ is normal for stock cammed cars.
Riley
smasher41
31
#11
  • Apr 21, 2009
  • #11
yeah, im about 20 also with full PI swap... somthing is wrong, very wrong.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Apr 21, 2009
#12
  • Apr 21, 2009
  • #12
I agree, but always be careful. I've used it to find a leak on a fuel injector, but stood back knowing it's flammable.
SFC.Kill
55
Parker Ford, PA
Apr 22, 2009
#13
  • Apr 22, 2009
  • #13
I found 3 leaks, a intake manifold bolt was even tighten, back in the right corner there is about a 3/8 inch rubber vacuum hose that goes from the back of the plenum, to some sort of black round valve, that hose is falling apart in my hands. Found coolant leak at back of thermostat housing.
squeak93
2,348
417
164
Joplin, Missouri
Apr 22, 2009
#14
  • Apr 22, 2009
  • #14
Did ur vac get any better?
R
Red04GT
10
Gardner, KS
Apr 24, 2009
#15
  • Apr 24, 2009
  • #15
yes i was kidding. but it does sound funny when someone says torch and vacuum leaks. i just like using a smoke machine.
SFC.Kill
55
Parker Ford, PA
Apr 25, 2009
#16
  • Apr 25, 2009
  • #16
Yeah it was the vacuum line going thru the firewall up to my gauge, the rubber grommet came loose so the plastic line had the leak.
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
