  • 1994 - 1995 Specific Tech
Vacuum leak = good idle?
  • Thread starter Thread starter Xticee
  • Start date Start date May 20, 2010
Xticee
38
  • May 20, 2010
I’ve been trying to cure a minor surging idle issue on my car, which, overall, runs pretty good. I reset the KAMS and loaded a new tune with slightly different TB air flow # and that’s when things got ugly. Car began hunting for idle & would only keep running with light tap of throttle. AFR is now hovering around 10 – 11:1 at idle. I went back to original tune & tried stock J4J1 and all tunes I've tried run just as badly.
So I’m thinking it’s a mechanical problem that the EEC learned to deal with over time. I started to try to eliminate things to narrow down the problem and found that the only time the car idles is when the vent tube between the valve cover oil filler tube and CAI is disconnected. In fact, idle quality is really good and settles in around 700 RPM like this. It seems odd that by creating a vacuum leak the car runs better. Is this an indication of a bad PCV valve or do you guys think that something else at play here?
Thanks for any help!
divit250r
314
Columbia City, IN
May 20, 2010
  • May 20, 2010
Is your idle air bypass valve working? I think that's what it does, create a regulated vacuum leak.
Xticee
38
  • May 20, 2010
Up until this happened I was able to datalog ISC and it was around 30%. So it was working, but I suppose it's possible it suddenly died. Unfortunately my computer is having issue w/newer version of BE, so I'm in the dark right now.
I don't want to drop $ on a new IAC if I don't have too though. What's a good way to test it? If I hook everything back up, unplug the IAC and if I see no difference in the performance, is this be a good sign it's toast?
hollywoodstang
1,095
May 20, 2010
  • May 20, 2010
clean the IAC and see if that helps, those things stick when dirty, If not you will have to bite the bullet and buy a new one
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
