vacuum line ? from stupid guy
mustangsquared
828
new bern nc
How in the H*ll do you get the vac line that goes from the canister to the intake connected to the intake...I keep splitting the stupid thing on the intake side. Thanks. (I tried using intake cleaner as lubercant with no results)
Well I just tried the old WD40 trick....nope aint happening. I plugged the intake hole (the one under the front of the intake next to the one that goes to the PCV) and then plugged the line. I think that hose has been the cause of my idle problem...too early to tell since it was intermidiate. Now to find a hose that will fit. what a PITA. Thanks for the help.
DK. I used 1/4 the whole way and it fit snug at the connector. Oh, did you know there is a connector (somewhere around the t-stat housing area) in that hose? That's why I'm sayin' you only need a foot or so. I didn't bother replacing the rest of the hose from that connector down to the cannister. Mine looked pretty good anyway and didn't feel like running it all the way down.
