vacuum line question
  • Thread starter Thread starter 87_GT
  • Start date Start date Nov 4, 2005
87_GT
179
tinley park, illinois
Nov 4, 2005
  • Nov 4, 2005
i am having trouble with my egr valve so i traced the green and red vacuum line in that loom back to like a 3 way connector. in that connector there was a green egr tube, a red intake maninfold (i think?) tube, and then there was this pink one, my pink one appears to be broken since there is nothing attached to it, where is this line supposed to go. btw the car is a 1995 gts. also what should the vacuum reading on the green line be? would the pink one not being hooked up to anything cause a problem?
thank you
ss93cobra
1,422
Wilmington NC
Nov 4, 2005
  • Nov 4, 2005
thank you
Does your car have the emissions label on it still as I'm not familiar with the 94-95 style...
87_GT
179
Nov 4, 2005
  • Nov 4, 2005
where would that label be?
HISSIN50
34
129
Nov 4, 2005
  • Nov 4, 2005
Here is one of Tom's diagrams.
And here is another.
Good luck.
18mustangs
533
Virginia Beach, VA
Nov 4, 2005
  • Nov 4, 2005
The label would be on the plastic panel over the radiator most likely, or on the underside of the hood (can't remember). I think the pink vacuum may go to the FPR, check your connections and make sure that you have a vacuum line on the EGR, FPR, and attached to the vacuum tree on the elbow, then make sure your thermactor vacuum tubes are connected to the two solenoids on the rubber hose leading from the smog pump. Happy Hunting!
Tim
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
