  • 1994 - 1995 Specific Tech
vacuum lines
  • Thread starter Thread starter KrazZ27
  • Start date Start date Feb 22, 2009
1 of 2 Next Last
KrazZ27
83
  • Feb 22, 2009
Alrite trying to clear the excess lines out what lines do i need and what do i not need?
HISSIN50
34
129
Feb 22, 2009
  • Feb 22, 2009
All the vac lines have a purpose or they would not be there.
Do you have emissions equipment on the car?
A little info is helpful.
KrazZ27
83
  • Feb 22, 2009
No smog pump egr valve will be blocked off do to valve covers....
HISSIN50
34
129
Feb 22, 2009
  • Feb 22, 2009
With such little info given (we don't even know the year of car or engine), this is tough.
Assuming you will not need the EGR again (and are able to turn it off with a tune or setting a hard code) nor the A.I.R. system, you should be able to remove and plug the feeds for the TAB, TAD and EVR.
KrazZ27
83
  • Feb 22, 2009
94 5.0 tfs intake 30lb injectors what more do you need this is just a basic question on what lines i can block off with out getting any lights...Ask me what you need and i will tell honestly at this point i just want to get ride of everything to clean up the engine bay...
HISSIN50
34
129
Feb 22, 2009
  • Feb 22, 2009
Here's a vacuum schematic.
toyman
1,944
54
79
Vernon BC
Feb 23, 2009
  • Feb 23, 2009
Geeze, JT, are you ever a stickler for details
RIO5.0
6,892
N.H.
Feb 23, 2009
  • Feb 23, 2009
No smog and EGR then all you need to feed is the purge soleniod on the firewall and your fuel pressure regulator...the rest of the vac lines are the PVC and a big hose that feeds the vac tee on the drivers inner fender..
The EGR feed in this pic can feed your FPR..This is a GT40/93 Cobra vac tree...depends on the type of upper you run...
KrazZ27
83
  • Feb 23, 2009
should i leave the egr valve plug in or can i remove it completely reason im asking is i put on bigger valve covers and my egr valve wont clear them with a 1 inch spacer..
HISSIN50
34
129
Feb 23, 2009
#10
  • Feb 23, 2009
  • #10
I think this thread was originally in 5.0 Tech, where we obviously have carbed, SD, MAF, etc cars. You really need specifics over there.
Stopsign32v
394
Gville, SC
Feb 23, 2009
#11
  • Feb 23, 2009
  • #11
So from the upper intake if you don't have a PCV or EGR could you just run a line to the fuel pressure regulator and I assume one to the vaccum tree? What about the power brakes? Does it need anything? Guy at Trickflow said yes..
KrazZ27
83
#12
  • Feb 24, 2009
  • #12
the brakes are controled from the tree but if i disconect the egr valve wont it throw a light?
Stopsign32v
394
Gville, SC
Feb 24, 2009
#13
  • Feb 24, 2009
  • #13
yea you will have to have the egr turned off with a tune.
RIO5.0
6,892
N.H.
Feb 24, 2009
#14
  • Feb 24, 2009
  • #14
You feed this from your upper...this Tee is what feeds the booster..
Unplug the EGR plug .... undo the 3 screws to remove the below from the EGR.... youll see a plunger.... secure this 1/2 way somehow, plug it back the the connector and stash it...your light will stay off... If you have a chip done then have them kill it for good... Mines homied like so... anything to hold that plunger 1/2/ way...
KrazZ27
83
#15
  • Feb 25, 2009
  • #15
Alrite i got everything hooked up like i was told but i forgot to hold the egr valve half way open. How ever i can not get the car to start im getting fuel and spark i have over 90 psi in each cylinder so i have compression but it sill will not start is it possible i have a leak that would cause it not to start? if so is there a way i can test the vacuum lines?
HISSIN50
34
129
Feb 25, 2009
#16
  • Feb 25, 2009
  • #16
You have fuel pressure or you have injector pulsing? You need both.
KrazZ27
83
#17
  • Feb 25, 2009
  • #17
How can i test for injecter pulsing?
RIO5.0
6,892
N.H.
Feb 25, 2009
#18
  • Feb 25, 2009
  • #18
Vacuum loss would cause it to run like ass... but it would run. recheck to see if somethings disconnected if it was running before...
What he said on the injector pulsing... Usually fuel and spark and no start would make me think TFI ???
HISSIN50
34
129
Feb 25, 2009
#19
  • Feb 25, 2009
  • #19
Use a noid light. Injectors receive constant accessory 12 volts. The ground to them is modulated via the EEC drivers. A noid is biased across an injector connector. Crank the engine and look for the noid to flash. No flash means we need to find an issue.
KrazZ27
83
#20
  • Feb 25, 2009
  • #20
The tfi is hooked up and was working fine before all of this...
1 of 2 Next Last
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
G
1980 Cobra - Vacuum Diagrams Needed
  • Gasmang
  • Oct 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
Smog delete /vacuum lines
  • Serg.Xof
  • Feb 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 18, 2026
RileyDymond
