I have always understood the purpose of the vacuum reservoir was to keep the vacuum assisted brakes from being erratic. I bypassed mine (temporary patch in the can is leaking) and just put a check valve in the line and it does not seem to make any difference. Brakes work fine, A/C controls are great, engine idle not effected. Any experience with this??
Far as I know the only reason for a vac can is to keep a constant high level of vaccum to run vac accesories like the brake booster. When dudes put in monster cams in their engine they run out of vacuum to run the booster.
