Vacuum Test
  • Thread starter Thread starter 88-GT
  • Start date Start date Jun 13, 2005
88-GT
183
Jun 13, 2005
  • Jun 13, 2005
Well I've been having suspicions of an aftermarket cam in my car so I decided I would try a vacuum test today. Vacuum showed rock steady 15 "hg at around 800-850 rmp idle. Hissin had told me to look for about 20 so would this be enough to show a cam? Not looking for anything huge but it does seem to have a lope. Thnx for any help.
silverstripes
81
monroe, LA
Jun 13, 2005
  • Jun 13, 2005
The lower the reading the more the cam generally.
In some forms of racing such as dirt track they allow a certain amount of vacuum loss from a cam. For instance they will set the rpm at 1000 and the engine will have to pull at least 14'' Hg or higher to pass inspection. This will generally pic out the guys running too much cam than is allowed for the class.
At 1000 rpm if the 5.0 is fairly good shape it should pull 18-20 with the stock cam and the less the vacuum the more the cam.
*This is just an overall estimate for 5.0 engines so please no critisizm on above remarks, some really like to nitpick these replys.*
silverstripes
81
monroe, LA
Jun 13, 2005
  • Jun 13, 2005
Oh yeah in my opinion this would most likely indicate a stock cam.
Just my thoughts.
88-GT
183
Jun 13, 2005
  • Jun 13, 2005
Yea I was kinda more looking for whether this was a big enough margin from 18-20 to 15 to rule in that the cam is not stock. It will determine the mods that I will do so it is kinda important. Would rather find out this way then pull a valve cover and and check it off the lifter.
88-GT
183
Jun 13, 2005
  • Jun 13, 2005
Bump
Sicarius428
2,085
Jun 13, 2005
  • Jun 13, 2005
I pull about 15Hg at idle with my e-cam. Bottom end has 135k on it.
Kevin
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 13, 2005
  • Jun 13, 2005
Would you build a combo based on a "mystery" cam anyway? Assume that it's stock and setup your combo the way you want it.
HISSIN50
34
129
Jun 14, 2005
  • Jun 14, 2005
FWIW, my 88 GT (SD) pulls 19.5" hg at 700 RPM.
You could just have a slight vac leak.
I doubt you would want to waver too far with regard to the vac characteristics of a cam or build-up, if you are still SD (we must have chatted awhile back, because this is not ringing a bell with me - but I am very tired right now [and get a few PM's from folks so my short term 'cache' can lapse]).
I would really look hard for a leak myself, before making further assumptions.
Good luck with it.
NosPony
278
Canton, Il
Jun 14, 2005
  • Jun 14, 2005
My coupe pulls about 11-12 hg. I have a victor jr intake and x303 cam.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
