  • SN95 4.6L Mustang Tech
Vacuum
  • Thread starter Thread starter USMstang
  • Start date Start date Jan 31, 2006
USMstang
114
Mississippi Gulf Coast
Jan 31, 2006
  • Jan 31, 2006
Is there any difference in vacuum pressure between the green lines and the red lines?
sgarlic
3,085
Feb 1, 2006
  • Feb 1, 2006
Why?
USMstang
114
Feb 1, 2006
  • Feb 1, 2006
I'm using an adjustable vacuum switch on my water injection and I pretty sure it (the switch) is not functioning properly. I have adjusted it in increments and the results are not monumental in difference. I have an led which lets me know when it is activated. I know that either the switch is defective or I am not utilizing a good vacuum source. I tapped into the vacuum line on the back side/left of the motor (looking from the front).
sgarlic
3,085
Feb 1, 2006
  • Feb 1, 2006
If you have a certain value that you're looking for (i.e. your setup requires a tap to a line with vacuum of more than 10hg or something,) you could always buy a cheap vacuum gauge from Walmart, etc, and check each line until you find one which suits your needs.
I'm not familiar at all with your setup, so that's just a very basic recommendation.
Good luck to you.
jstreet0204
939
Winston Salem, NC
Feb 1, 2006
  • Feb 1, 2006
Try tapping the vacuum line going to the fuel pressure sensor. I know that is a good source since that is the source used for the bypass on my supercharger. If that one doesn't work, you know it is the switch.
USMstang
114
Feb 1, 2006
  • Feb 1, 2006
Where is the line for the fuel pressure sensor located? Thanks
jstreet0204
939
Winston Salem, NC
Feb 1, 2006
  • Feb 1, 2006
It should be on top of the drivers side fuel rail, unless they changed it since 99.
USMstang
114
Feb 1, 2006
  • Feb 1, 2006
It's still there. I think it's a bad switch because the line I'm tapped into originates at the same point as the one for the fuel pressure sensor. I appreciate the help with this one. Because we are still feeling the effects of Katrina down here, it's tough getting to parts houses and/or wal mart or wherever. All those places are either destroyed or work limited hours...still! I can order another switch for a lot less pain than driving around searching. Thanks again to ya'll for responding.
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Explorer intake vacuum port
  • JD1964
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 29, 2026
Mustang5L5
Engine vacuum
  • KAWMAN2
  • Aug 1, 2026
Fox 5.0 Mustang Tech Aug 7, 2026
Mustang5L5
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
