Valve body-clunk question
Hi all,
About 2 years ago i had my tranny rebuilt and a shift kit put in. At the same time my rear control arms and shocks were replaced. Ever since then I have had a terrible clunk / squeak after the car shifts into gear NOT UNDER ACCELERATOR LOAD which is way worse going into OD. I recently had the trac loc replaced, the backlash on the ring and pinion rechecked and the rear suspension re-checked. All of this helped, but did not solve the problem.
I called the tranny shop and asked if they could "lower" the shift kit b/c it seems to me that the problem comes from the pressure and rpms building but the tranny not shifting in time so when i let off the gas it slams back into gear (the next one i think). This will not happen if i dont let off the gas.
Anyway they cannot do that, they can try to "uninstall" the shift kit and set the valve body back to stock or for about 350 install a brand new valve body which should eliminate the added pressure and make the shifting etc much more gentle.
Does this seem feasible? I hate to get rid of the shift kit and spend another 350 and still have it clunk along.
Please help.
Thanks
