Valve clearence?
what i'm doing is taking stock worked over heads valves and so forth from a 87-93 5.0 roller motor and putting them on my 95 motor. i dont know if they are the same heads that our S/N's came out with iwould assume that they are the same heads ? it's all 5.0 stuff the new heads and my block is. peace
john :p
SMOKEDYA said:
will it be an issue if i'm going with stock heads from a 87-93 5.0? or is it only an issue with aftermarket ones? peace
john :p
as far as valve clearance goes that all has to do with the diameter of the valve and how much lift/duration the cam has.
If its all stock you have no problem. if not check it.
