Valve Cover and Push Rod Q's
  • Thread starter Thread starter srjs28
  • Start date Start date Apr 6, 2010
srjs28
69
  • Apr 6, 2010
i have stock valve covers i am going to polish but not sure if they will be tall enough for my valve train _ 1.72 RR's, heavy springs, comp cam xe-270-hr-12 or part number 35-312-8 cam for 1.7 RR's, INT .544 and EXH .566. (also hope this will work with stock pistons.) could the xe-270hr-14 work with the 1.7RR's? its the same cam as above but supposed to be used with 1.6RR's. also whats the proper way to measure for pushrod length. i think the stock might be ok but not sure. i dont want to use them with the heavy springs and aggressive cam anyway. thanks for reading, hope someone can make sense of my incoherent rambling.
srjs28
69
  • Apr 8, 2010
surley somebody knows something
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Apr 8, 2010
  • Apr 8, 2010
I didn't clear with a .512in .533exh and 1.6 rockers on the stock valve covers. You should always check for piston to valve clearance. You need to buy an adjustable pushrod to find the "correct" length.
Vinnietbird
584
  • Apr 8, 2010
My friend used doubled up cork/rubber valve cover gaskets to make them fit. I bought new taller valve covers.
srjs28
69
  • Apr 9, 2010
how can i check piston to valve clearance? what tools are needed? also whats the process of checking pushrod length? assemble valvetrain, turn one rocker, insert adjustable pushrod, turn rocker back and check length? what kind of free play / tolerances do i need for piston to valve and push rod to rocker.?
Blandnuts
1,172
124
124
FloorDuh
Apr 9, 2010
  • Apr 9, 2010
With a quick search these came up......
Push rod length http://*******.com/index.php/topic,317.0.html
People go back and forth about the sweep being in the middle or wherever you can get the smallest sweep (slightly off the middle of the valve).
Piston to valve clearance RHS® - Sorry...
Well, do a search and you'll get the same sites I did since they won't show up. small block ford.com (abbreviated)
Valve Train Issues
  • Dane Brahler
  • Apr 5, 2017
Fox 5.0 Mustang Tech Apr 6, 2017
liljoe07
My RNH 347 is finally running
  • just4bob50
  • Aug 11, 2008
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 11, 2008
just4bob50
Are these heads any good for 414c.i.?
  • Pokageek
  • Jun 5, 2008
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jun 5, 2008
5spd GT
AFR and Trickflow Head Information
  • 5spd GT
  • Aug 19, 2007
71K
Fox 5.0 Mustang Tech Apr 19, 2012
NIKwoaC
N
Experts estimate this motor's hp, please
  • nidyanazo
  • Nov 18, 2006
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 26, 2006
GTOreturns
G
