Alright, I was installing my new valve covers tonight and one of the bolts broke off. The bolt is on the bottom middle of the valve cover. If I remove the valve cover, you can get a pair of vice grips around the top section of the bot. The vice grips do nothing in trying to remove the bolt. the bolt will not budge. Any suggestions on getting this thing out?? Thanks!!!
you know how hot it has to get? EXTREMELY hot before it can do that.. and use a torch.. heat the bolt and the head.. principles are principles but it sure as hell works well.. i did it that way.. garuntee you the heads arent screwed..
