valve Cover Bolt Snapped!!
88GTStreetRod
376
USA
Alright, I was installing my new valve covers tonight and one of the bolts broke off. The bolt is on the bottom middle of the valve cover. If I remove the valve cover, you can get a pair of vice grips around the top section of the bot. The vice grips do nothing in trying to remove the bolt. the bolt will not budge. Any suggestions on getting this thing out?? Thanks!!!
steel or aluminum heads? spray with PB blaster heat bolt up with soldier iron or torch be careful not to use too much heat as too affect head. tap with hammer and you can use a hacksaw blade and cut a groove across center and use a rachet and 1/4 in socket with a flat head screwdriver bit to remove bolt be careful not to break bolt with screwdriver bit at the cut and you may have to repeat heating,tapping and PB blaster until. removed
you might be able to spray some wd40 or pb blaster on it and let it set for half an hour or so. I don't think I would be applying heat to my heads.
bill: Seems like heating the bolt would make the bolt expand, which kinda is counter-productive. Heating the head might help, but might result in some head warpage. This would be my last resort.
find out the exact bolt size,go to the hardware store and buy an extractor for that size bolt and the proper drill bit for the extractor use a punch and make a divot dead center of the break then drill into the bolt with the bit,put the extractor in the hole and make sure its straight and back it out.
I think the expansion caused by the heat might crack the rush or whatever is holding the bolt in place.
I usually just notch the bolt with a dremel cut off wheel and back it out with a flathead screwdriver. If that dosent work for you, you can weld a nut on top of the broken bolt and back that out. That is if you have/know someone with a welder.
88GTStreetRod said:
I will try the penetrating oil and the dremel first. What is an Easy Out?
a easy out is an extractor its kinda like a reverse threaded drill bit but more of an aggressive thread and it is the way i would go i use them daily at work and by far the best method to do what u need to do.
same thing happened to me, one bolt on both heads, my dad tried tapping it but it didnt work, so he basically drilled out the bolt and put a bolt in the hole with jb weld, and used a nut to tighten it, its ghetto i know, but it worked, not leaking oil
The dremel did not work, The bolt is very soft, once I had my slit cut for the srew driver, I tried unscrewing. The screw driver snapped one side of the bolt off. Now I am going to the maching shop with it. I think the bolt is cross threaded. I hand tightened the bolt, so it does not make sense, it screwed in very easy.
:bs: you know how hot it has to get? EXTREMELY hot before it can do that.. and use a torch.. heat the bolt and the head.. principles are principles but it sure as hell works well.. i did it that way.. garuntee you the heads arent screwed..
Have you guys come across this before?I can`t recall hearing a valve cover bolt breaking off.
It`s the water pump bolts/studs that like to break off and give you the headaches.
Is this a cast iron or aluminum head?
I did this once in a 66 mustang. quickly became a nightmare.
Had to drill the entire thing out. In the process, the raised area that the bolt threaded into completely collapsed, then we drilled accidently into the water jacket.
****, after that, shoved some jbweld down to plug the water jacket hole, Put the bolt where it was supposed to go, and stacked jbweld around it to make the base for the threads to go into, then shaved the excess jb off with a razor to look oem.
Car ran like that years and years and years with no issues.
