Valve Cover Clearance
  • Thread starter Thread starter 1Slow5oh
  • Start date Start date Sep 15, 2004
1Slow5oh
92
Bartonville, IL
Sep 15, 2004
  • Sep 15, 2004
I have aluminum FR valve covers and used to have them on a carbed car. No clearance problems.(sold) Now that im putting them on my 90 There is a huge problem throttle body hits hardcore. Ive placed (temporary) spacer between the intakes to see how much of a spacer I will need and I need more than an inch. I have not seen a 1inch or larger spacer for upper intake nor do I want to add that much of a spacer. Is there anyting I can do to move the kickdown assembly or any other solution you can think of?
Besides buying a high rise intake.(Money is a big concern)
Anybody seen a large upper intake spacer?
Im really wanting to drive my car.... Sniffle sniffle
88stangmangt
2,332
Stafford,VA
Sep 15, 2004
  • Sep 15, 2004
i havent................im sure there has got to be something out there that will work with a spacer and clear.
giddyup306
3,041
Sep 15, 2004
  • Sep 15, 2004
Are you running just the stock intake? If worst comes to worst I guess you could silicone two spacers together.
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Sep 15, 2004
  • Sep 15, 2004
i drilled new hiles into the throttle cable bracket. So it mounts higher. But it still pretty much rests on the valve cover.
1Slow5oh
92
Bartonville, IL
Sep 16, 2004
  • Sep 16, 2004
Yes I still have stock upper/lower.
Scott_B said:
I drilled new hiles into the throttle cable bracket. So it mounts higher. But it still pretty much rests on the valve cover.
Im thinking you mean where it bolts to the upper? I see you have TF intake are those the same as stock height?
BTW.... Nice quad. I got a fo-fiddy. Where you ride?
C
conolty87
Southern indiana
Jan 20, 2008
  • Jan 20, 2008
Canton makes valve covers that are 1/4 inch taller and clear my comp rollers (cutting out baffle) and fit under stock intake and TB. i would check them out they look great!
D
Djstorm100
109
  • Jan 21, 2008
in for answer
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 21, 2008
  • Jan 21, 2008
yeah your gonna have to make something the EFI and Carb style valve covers are way different in height. Jegs sells them in 1/2 and 3/8 for stock intake patterns looks like your stack'n
millhouse
1,985
Simpsonville, SC
Jan 21, 2008
  • Jan 21, 2008
It sounds like your going to need to go with a stock height valve cover. If rocker clearance is a concern, I know my trick flows clear my 1.7 stud mount setup.
J
  • Locked
SOLD 93 cobra intake manifold
  • Jimmer009
  • Jan 19, 2025
  • Engine and Power Adder
Engine and Power Adder Jan 22, 2025
Jimmer009
J
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
