  • 1994 - 1995 Specific Tech
Valve cover differences
  • Thread starter Thread starter DMacRacer
  • Start date Start date Apr 11, 2007
D
DMacRacer
28
  • Apr 11, 2007
What is the difference in valve covers between 93 and 94-95? Is it the height, 93's
being taller. If I use a Phenolic spacer can I use the 93's?
DarkProphet
391
Quakertown, PA
Apr 11, 2007
  • Apr 11, 2007
I believe the 94-95 covers were a bit shorter to clear the elbow in the intake manifold. The placement of the oil fill tube is a little different too if I recall. Im running fox covers on mine and had to move (bend) the fill tube a bit to clear. I have a .5" spacer (I think, it may be taller) and a cobra intake and it clears. You deffinatly need a spacer though!
MI95Cobra
451
Oklahoma City
Apr 11, 2007
  • Apr 11, 2007
the filler tube on the 93 and older sit right under the throttle body....it will be ok if you have an after market intake or you can cut the filler tube and use a radiator hose to move the upper filler tube(the one you just cut) between the throttle body and alternator....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 11, 2007
  • Apr 11, 2007
Besides the filler neck location being in a different location ............
You will have a bit more room under the Fox VC's.
The lip around the Fox VC's are thicker requiring you to find
longer bolts.
Grady
D
DMacRacer
28
  • Apr 13, 2007
Thanks, I'm thinking of trying a set of the finned Cobras with a 94-95 Cobra intake.
DarkProphet
391
Quakertown, PA
Apr 14, 2007
  • Apr 14, 2007
If your talking about the same ones I think you are, your going to need a spacer.. I needed about .75" to make it fit, but wound up selling them and using stock fox covers.
99FiveOh
2,051
20
99
J-Ville, FL
Apr 15, 2007
  • Apr 15, 2007
When i installed a set of stock Fox covers on my car, I had to grind away some material right behind the alternator. The lower alternator housing bolt interferes with the valve cover. No big deal really. And the EGR valve as well as the mounting flange on the intake had to be grinded down slightly to clear the cover.
I love the look of polished Fox covers as well as extra rocker arm clearance.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:54 AM
keel
