  • SN95 4.6L Mustang Tech
valve cover gasket
  • Thread starter Thread starter spederman
  • Start date Start date May 30, 2009
spederman
732
  • May 30, 2009
Couple of questions:
1) is it ok to re use the original valve cover gaskets if they look fine? (7 year old gaskets but rubber shouldnt break down, right?)
2) what is the purpose of using the RTV in the two spots on the head? Do i have to do that again?
lazerred02
190
FT Stewart, GA
May 31, 2009
  • May 31, 2009
Yes they should be fine to reuse again as long as they are still in one piece and look ok.
Use a razor blade and get that old RTV off and reapply some more in the same spots when you put the valve cover back on, it is just to seal the front cover to the block in those 2 spots on each side.
spederman
732
  • May 31, 2009
thanks, but i figured I might as well as play it safe and just buy new gaskets. Not worth tearing it all down again for $30.
Why are there so many different part numbers for the valve cover gaskets? I have these part numbers and they all come up with the same application gaskets.
F6AZ-6584-AA (RH) and F6AZ-6584-BA (LH)
2C2Z-6584-AA (RH) and 2C2Z-6584-BA (LH)
2L3Z-6584-AA (LH) and 2L3Z-6584-BA (RH)
lazerred02
190
FT Stewart, GA
May 31, 2009
  • May 31, 2009
Not sure about all the different part numbers, I am sure that your local Ford parts manager can get you the right ones.
R.J.
813
Warwick, Rhode Island
May 31, 2009
  • May 31, 2009
The difference is Romeo or Windsor Heads. Just tell the dealer how many bolts you have in each VC and they will get you the correct one. If you already have the VC's off just look at your cam caps. If the are caps (individual 2 bolts each) and not cages then you have a Windsor head.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
SN95 V6 Mustang Tech May 23, 2026
DPP
D
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
