  • 1994 - 1995 Specific Tech
valve cover question
  • Thread starter Thread starter 94gts
  • Start date Start date Apr 22, 2005
94gts
873
Carmel, New York
Apr 22, 2005
  • Apr 22, 2005
i have iron gt 40's with 1.7 rockers. here is my situation.
when we did my heads we thought we had the rockers hitting the baffle in the passenger valve cover so we removed it. turns out the rocker was not hitting and it was the egr tube leaking . anyway, we didnt realize no baffle meant oil would be sucked into the intake from the fillerneck(the little hose there). so we removed the hose, capped the holes, and threw a breather on there which gets moist and drips . also the valve cover leaks where the filler neck meets it(temporarily fixed with silicon ). so hear are my 2 questios....
1) do i need a breather or can i keep the oil cap on with no ventalation?
2)Or should i just get some fox valve covers with the baflle still in them?
94gts
873
Carmel, New York
Apr 23, 2005
  • Apr 23, 2005
anyone?
RIO5.0
6,892
N.H.
Apr 23, 2005
  • Apr 23, 2005
I would think you should be venting that somehow...its not a closed system...
FRPP sells the M6766-N303 screw on breather that looks like a KN...
94gts
873
Carmel, New York
Apr 23, 2005
  • Apr 23, 2005
i have a breather on there now.
when it vents it makes the breather moist with oil because there is no baffle in the valve cover. and it leaks/drips all over. my freind in his 88 gt(he is a mechanic) has his vent tube removed has the oil cap on the filler neck with no ventalation, he said it is for emissions and it has no purpose. does my ranting make any sense?
vristang
4,933
101
124
Seattle
Apr 23, 2005
  • Apr 23, 2005
Your mechanic friend is a little confused. The vent must be there to allow crankcase pressure to safely purge. If it does not have somewhere to vent you will start to blow oil pan and lower intake gaskets. It vents to the intake manifold for emissions reasons. By venting to the intake the oil vapors are burned instead of venting all those HC's to the atmosphere.
Make sure your PCV is working properly, as this is where most of the pressure is supposed to be venting. Your best bet is to use valve covers with baffles if they will clear the rockers. This way you should be able to use a breather, or be a hippie and vent to the intake. If you cannot do this then try an oil seperator setup. I think Steeda has one?
As an aside: Not all "professional" mechanics were created equally. But, I won't rant on this again.
94gts
873
Carmel, New York
Apr 23, 2005
  • Apr 23, 2005
ok i knew it had to be there for a reason. i can get a pair of fox valve covers cheap, so i think i will get them. how hard is it to make them work or is it not hard at all?
vristang
4,933
101
124
Seattle
Apr 23, 2005
  • Apr 23, 2005
As long as they clear the rockers they should be a direct swap.
94gts
873
Carmel, New York
May 3, 2005
  • May 3, 2005
somebody told me something about needing fox valve cover bolts because the fox vc's are thicker....make any sense?
lager94GT
119
LI, NY
May 3, 2005
  • May 3, 2005
I use fox vc's with FMS 1.6 (blue) rockers and I had to remove the baffle. The fox vc will have to be 'slightly' notched near the #1 cylinder to clear a bolt on the alternator. This is easily done with a dremel-type tool.
94gts
873
Carmel, New York
May 3, 2005
#10
  • May 3, 2005
  • #10
lager94GT said:
I use fox vc's with FMS 1.6 (blue) rockers and I had to remove the baffle. The fox vc will have to be 'slightly' notched near the #1 cylinder to clear a bolt on the alternator. This is easily done with a dremel-type tool.[/QUOT
what abot the bolts, did you reuse the stock ones? what did you do with no baffle as far as oil being pushed up into the filler neck?. thanks, kyle
M
mustang_2099
25
Camrose AB, Canada
May 3, 2005
#11
  • May 3, 2005
  • #11
I used the stock covers with 1.7 rockers and the were hitting the bezzel sooo.... I took off the bezzel ground down the three 'pedistals' that the bezzel was screwed into then put the bezzel back on almost 1/4 inch higher then stock and after that i had the bezzel and the rockers cleared by more then enough room..... ( if you want to keep the bezzel!?!!)
vristang
4,933
101
124
Seattle
May 3, 2005
#12
  • May 3, 2005
  • #12
Awesome solution
I will try to do this as I am rebuilding my motor now.
The bolts should be close enough to the same length that is won't matter. If not, just go to the local hardware store and pick something up.
CBZGT50
171
St Louis area
May 3, 2005
#13
  • May 3, 2005
  • #13
I have a set of Cobra valve covers from my 95 cobra if you are interested. I replaced mine with custom chrome plated Cobra VC's. If you have GT40 heads and pedestal mount RR's these VC's will work great. PM me if you are interested.
Chris
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Valve cover leak
  • joetiii
  • May 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 14, 2025
General karthief
A
Engine Genius installed oil filler above rocker arm…
  • afjLX
  • Mar 27, 2025
Fox 5.0 Mustang Tech Mar 29, 2025
nicholase
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
P
Resolved P0457 with intermittent fuel odor in cabin
  • PSKSAM2
  • Jun 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2025
