valve covers
Those aren't stock 94/95 Cobra valve covers just to let you know. If you really want to convert your car to a 94/95 Cobra check the classifieds on the corral and you can usually find a set there.
Good luck
Jake
viperos said:
well, I was thinking of doing that too, same covers... they will NOT fit on a stock GT 5.0L engine? the 302, for anyone who really didn't know :D
i should have been clear as to why they dont fit. its not the bolt pattern its the space under the intake if u get a spacer for the intake to raise it about an 3/4 to an inch i do believe they will work i only know of the 1 inch phenolic spacer for the GT40 and cobra style intakes. also note hood clearance will become an issue.
viperos said:
yes, I have a 1995 GT (in my sig :D) darn... had an offer for both sides for $20... guy didn't know what he had... will running w/ a spacer help/hinder my performance at all? never read anything about it on an intake, just TB...
im no guru on the spacers actual performance gains or losses but everything i read and understood is that u gain lowend and lose some topend ( torque, not sure on HP ) with the spacer but as i mentioned earlier the biggest problem will be hood clearance. also the TB will be raised with the intake. oh and if u have the stock tower brace i do believe this will have clearance issues as well.( but it has issues with the cobra intake as well ) there is more issues than people like to deal with just for chrome covers. every now and again you may catch someone who just gets their stock covers chromed.
If you end up buying them and running a 1 inch spacer you will most likely run into some hood clearance problems, just something to consider. BTW- A spacer moves the powerband down, so your powernabd would shift down a little with the 1 incher on there.
