valve life on edelbrock heads with this cam
9150ho
83
how long will the stock valve springs on the edelbrock performer cylinder heads last with a cam that has .544/.560 with 220/224 duration and 114 lsa?? they say the springs will handle up to .575 lift, but for how long? thanks.
The cam card will tell you what the open pressure & the seat pressure of the valve spring will need to be. As long as they match (spring pressure should be slightly higher than what the cam card calls for, for best durability) then it will work fine.
Can you tell me what spring pressures are listed on the cam card? it'll say "Open" pressure & "closed" pressure (also called seat pressure.
hmmmm, i dont actually have the cam yet, but i know the part number if that will help? its a comp cams 35-312-8. Im overseas right now so dont have access to a phone or a solid mail address, so my way of getting information is limited. thanks.
Well I checked comps web site & the don't mention anything on-line about the spring pressures or even the recomended springs:
Camshaft Specification Table
Part Number 35-312-8
Engine 1969-1995 Ford
351ci,
Windsor,
8cyl.
Grind Number FW 276H-R14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.544 0.56
Duration At 0.006 Tappet Lift 276 280
Valve Timing At 0.006
Open Close
Intake 28 68
Exhaust 78 22
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 220 224
Lobe Lift 0.34 0.35
Lobe Separation 114
Recommended Valve Springs
If it helps at all my cam is 220/226 @.050 with .510 lift.... using stock edelbrock springs. I'd think based off the info I have the stock edelbrock springs would be fine.
if your going to run it hard, which I assume you will,, I would allow for more room that just .010 of lift. I would get a set that were good to .600 which I thought the edel heads were good for. I have a set on my car and I thought thats what the springs were rated too.. Never hurts to get the proper springs with the cam though! It's good insurance.
With .544 lift cam he'll have .031 clearence before spring/valve bind. Edelbrock springs are good to .575 lift... extra insurance is good & I do recommend that he double check the spring requirments once he get's his hands on a Cam Card.
