  • 1994 - 1995 Specific Tech
Valve Noise
  • Thread starter Thread starter miklzlx
  • Start date Start date Nov 12, 2008
miklzlx
  • Nov 12, 2008
I have a 95 GT with a stock motor, here recently I started to have a noise I believe is one of my valve hitting a piston seems to get worse as the car gets warmer and also little to no noise at low RPMs such as 2k and below, and gets louder and harder at higher RPMs. I have removed the valve covers and everything looks good under there except one rocker arm that seems to be loose but the is as tight as need be. So I was thinking maybe a lifter has bought the farms. Sorry for the long spill, but im seperating from the military soon and have to drive it 8 hours home. Any advice would be great, thanks ahead of time.
earleys94gt
1,223
Ashley, Ohio
Nov 12, 2008
  • Nov 12, 2008
Sounds like a lifter bit the dust.
If it were the valve hitting the piston, you would know it. You sould hear the chunks of metal clanging around in the bottom end.
ScratchinFerTra
68
Mebane, NC
Nov 13, 2008
  • Nov 13, 2008
Worst case scenario, if you did isolate which cylinder it is, remove both intake/exhaust rocker arm, and disconnect that injector from the harness to make your 8 hour drive, just drive with sense.
Stan
toyman
1,944
54
79
Vernon BC
Nov 13, 2008
  • Nov 13, 2008
Stan
Let's suppose it is a lifter that isn't working or is only partially working. What exactly would happen during an eight hour drive that is avoided by removing the 2 rocker arms on that cylinder. I can't think of any real downside risk of leaving it alone but I'm obviously missing something.
Zero Signal
2,633
Tucson, AZ
Nov 14, 2008
  • Nov 14, 2008
It sounds like a collapsed lifter or bend pushrod to me. Not fun to tear out the entire top end to replace it but that's what you need to do. I wouldn't worry about any catastrophic failure because of it, it will just be very annoying, but that's just my opinion. I've had collapsed lifters before and never had a problem running the car with them, just don't get too throttle happy.
You can possibly try changing oil to something with a lower viscosity to see if it pumps up.
I wouldn't try removing rockers and pushrods. Then you end up with lifters bouncing around in there with no support, possibly damaging the retainers, which could cause a lifter to rotate and you're REALLY screwed. Plus the engine will run horribly with a cylinder that's dead with no valve movement. A dead cylinder is tolerable if the valves are still moving.
toyman
1,944
54
79
Vernon BC
Nov 14, 2008
  • Nov 14, 2008
QUOTE=Zero Signal;7707839]It sounds like a collapsed lifter or bend pushrod to me. Not fun to tear out the entire top end to replace it but that's what you need to do. I wouldn't worry about any catastrophic failure because of it, it will just be very annoying, but that's just my opinion. I've had collapsed lifters before and never had a problem running the car with them, just don't get too throttle happy.
That was my thought as well.
At one time and perhaps still today one could by high detergent oil to clean engine internals. If it's still available you might try that.
[/QUOTE]
Agreed
R
RumbleFox
15
  • Nov 15, 2008
Like that one guy said, try the easiest crap first, change the oil and go to a little more viscous(heavier) weight.
If it's still doing it, pull the manifold(s) and inspect THE ENTIRETY of your valvetrain, and dont just eye-ball the rockers. I mean check everything, the spider, dogbones, each lifter, each pushrod, and each rocker.
And take your time with it, ~8 hours with minimal rest-stopping can be hell on a motor.
T
  • Locked
Ticking noise as I accelerate
  • tazman 46
  • Jun 24, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 24, 2025
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
