  • 2.3L (N/A & Turbo) Tech
Valve Seals question??
  • Thread starter Thread starter Lex
  • Start date Start date Jun 8, 2004
Lex
248
Halifax NS. Canada
Jun 8, 2004
  • Jun 8, 2004
Valve Seals question?? Well, after smogging many people out. I realize that I have been burning oil. I need to replace my Valve Seals. on top of it I have a sewing machine sound (under my OHC cover), so I have to replace the followers. So I figured that well Hell , since I'm dumping money into this project , the cam must of well be replace because it wore out too. The point and question is, Is there a choice to cams I can choose from to get a bit better HP without F'ing up the engine? Thanks.
Edit. I just realized this was not a valve seal question. Sorry
mr_woodster
1,314
Riverside, CA
Jun 8, 2004
  • Jun 8, 2004
if your getting a ticking from under the cover, chances are its not a follower, its going to be a Lifter. OHC motors always make some ticking becuase everything is on top of the motor, you hear it more. Unusual ticking is when it sounds like something is breaking or falling apart. If you choose to go with an aftermarket cam you will need to do some research as to how to do a cam swap. As far as your question, many people go with a roller cam A237 from ford, with this swap you'll either hafta buy roller followers from a ranger cam setup or pick them up from esslinger/ford.
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 23, 2026
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
SN95 V6 Mustang Tech May 23, 2026
DPP
D
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
