Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
93gtmustang
523
42
49
I have M-6049-X-303 Ford Racing Aluminum Heads.
I would like to try and install this kit to prevent valve float at higher rpms drag racing.
It requires beehive-specific retainers, locks, and valve stem seals, properly sized spring locators and shims.
Where can I purchase these?
And find detailed how-to instructions?
Thanks
Do you have valve float? Really going to depend on your cam specs that you are using.
I second talking to Ed. I got my cam and spring kit from him, as he sells complete kits.
I would say yes for valve float. Not all the time. But I can tell sometimes when it lays over before the stripe with certain weather conditions.
The motor is the old Ford Racing Crate stock 5.0 bottom end with the B-303 cam and the Gt-40 X-303 heads
I've read that the Gt40 x-303 heads are only good for like 5500-5800 rpm I guess. I am hitting the finish line at 6000-6100 rpm.
I want to buy heads that will flow 6000 rpm and a new cam but, It's not in the budget right now.
Thanks for the link! I will give him a call.
I wonder what lifters are in that crate motor? By this I mean are the the M-6500-R302's or the M-6500-R302H's? If you remember the crate motor part number you could call Ford Performance and see if they would have an idea as to which lifters are in it. If it is the M-6007-XB3 then on that instruction sheet (see attached) it just says "Current production lifters".
This excerpt is from the 2020 Ford Performance Parts catalog on page 138:
M-6500-R302H DESCRIPTION
It’s not often that little changes can deliver big results – but in the case of the Ford Performance R302H Lifter, that’s exactly the result.
Before getting into the technical details of the lifter, here’s the background on why and how this special lifter was developed by the engineers at Ford Performance. Circle track racers who use the production hydraulic roller lifter in 347 crate engines reported that their engine seemed to lose power during long green flag runs. Dyno testing by Ford Performance engineers confirmed that – and showed a dramatic performance fall off over 6000 rpm with hot oil temperatures. The problem was traced to the piddle valve check ball, which would become unseated at high rpm when the oil got hot. The fix was a lighter-weight ceramic piddle valve check ball combined with a higher-rate piddle valve spring to keep it seated. The results of these two small changes were impressive – and noticeable by the racers. The power range was extended 300-400 rpm in hot operating conditions – and more importantly, the performance fall off on those long runs was gone.
This unique lifter construction for a drop-in hydraulic roller lifter is an exclusive from Ford Performance and fits any small block Ford roller cam application. While the R302H was developed specifically for racing conditions, it’s the right choice when assembling a high-performance small block that uses a hydraulic roller camshaft.
It could be that you are experiencing the issues they had with the non-H models.
I would still go to a better spring as it's just time in the river and drag motors tend to live at high rpms so they will wear a spring out faster than a street car even though its only 1/8 or 1/4 mile at a time.
Reactions: 93gtmustang
I just saw this:
From this thread:
Send them an email and tell them what you've got and what you need.
Here's the complete 2006 For Racing catalog.
Page 86 is the info on the crate engine. Mine is the M-6007-XB3M.
I didn't know the heads had roller rockers lol!
The current production lifter. On page 86 it shows part number M-6500-R302. So, I assume that is the one that was used?
Just got this from flow tech induction.
They are not taking calls just e-mails.
This is a beehive spring kit that was developed for the GT40 castings.
https://flowtechinduction.com/fti-gt40-k1-beehive-valve-spring-kit/
The current pricing for the FTI-GT40-K1 Beehive Valve Spring Kit: $465.00 plus shipping.
Shipping quotes will require the "ship to" address and contact number for an accurate cost.
For payment, we are currently using Venmo with their friends payment system for this type of purchase.
If you have any other items required to complete the installation, let us know.
Tech
