  • 1994 - 1995 Specific Tech
Valve springs question
  • Thread starter Thread starter BlackVert
  • Start date Start date Sep 12, 2006
BlackVert
5,589
9
98
Bethesda, MD
Sep 12, 2006
  • Sep 12, 2006
Is the rating an indication of how much pressure the springs exert on the valves to keep the valves from floating at high rpms?
If my valve springs are rated for up to .500" lift, can I "get away" with a cam that lifts the valves to .512" and .533" if I keep the rpm below 5000?
I never rev my engine past 5000 rpm anyway.
Y
yellow1995Cobra
2,959
Massachusetts
Sep 12, 2006
  • Sep 12, 2006
is this a serious question?
BlackVert
5,589
9
98
Bethesda, MD
Sep 12, 2006
  • Sep 12, 2006
actually, it was ... which shows how little i know about that part of the engine.
but i am realizing that it is more than just a question of valve float. it also has to do with the thickness of the spring when the valve is fully compressed and if the lift is too far, then the springs hit bottom and things can and probably will break.
Y
yellow1995Cobra
2,959
Massachusetts
Sep 12, 2006
  • Sep 12, 2006
That part of the question i can see. But the part about never revving above 5k kills me. I mean comon?
Anyways, my one tip in the car game, just the spend the few extra bucks and do it right. Dont cheap out on springs, crappy heads, crappy pistons, and so on.
BlackVert
5,589
9
98
Bethesda, MD
Sep 12, 2006
  • Sep 12, 2006
yeah, i don't rev past 5000 ... i guess i'm an old fuddy-duddy
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 12, 2006
  • Sep 12, 2006
On a stock h/c/i car you shouldn't rev past 5k anyway, lose power. Better to shift at 5k.
but seriously, get the correct valve springs. Because everyone knows how easy it is to accidently rev the motor out by missing the brake pedal, or missing a shift.
Scott
Y
yellow1995Cobra
2,959
Massachusetts
Sep 13, 2006
  • Sep 13, 2006
Scott
His car isnt stock.
scarless
175
  • Sep 18, 2006
BlackVert said:
If my valve springs are rated for up to .500" lift, can I "get away" with a cam that lifts the valves to .512" and .533".
The answer is NO. If a cam has a .512 lift and your springs have a bind height of .500, then you are going to bend pushrods and break things.
Therian
The Highlander
Waterloo, Ontario
Sep 18, 2006
  • Sep 18, 2006
why do you want a cam with that high of lift if you want to make maximum power at 5000rpm? (or lower)
scarless
175
#10
  • Sep 18, 2006
  • #10
I don't consider .512 to .533 to be a high lift cam. The faster the valve gets to its max flow lift the more power he will make.
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
