Trying to sort out the various things changed or modified on the '94 GT I recently bought. Tonight, the vapor recovery system. The canister is gone, the control valves are gone, all that remains (that I can see readily) are two 3/16" nylon vacuum tubes coming from within the right front fender well. They are plugged with setscrews.
My question is: can anyone tell me what was used as vapor line from the tank? Was it steel tubing like gas line, or nylon stuff? Where did it terminate? Was it maybe where the fuel lines enter up against the RH firewall? Then what form to Canister, nylon tubing? Was the canister mounted against the RH front fenderwell, or within it? The TFI is mounted there, looks like a non-stock mounting job.
Any help appreciated! imp
