I took the car out yesterday, and noticed a strong gas smell during idle. I checked the top lip on the tank, it wet, from gas.
I dropped the tank today. Thank god the tank was almost empty. Looks like the leak was coming from the vapor valve Seal. The rubber grommet for the vapor valve Seal was cracked, all over. I thought it would've been the fuel pump seal.
When I was dropping the tank I noticed the hose coming off the Vapor Valve was pinched flat, between the tank and the body. I can't find a carbon canister on the car, anywhere. So not sure if this was done purposely?
So now the question. Would the cracked, Vapor Valve Seal, be the cause of the leak? Would the pinched Vapor Valve line, cause the leak? Seams like a strange spot for a leak, seeing how the vapor valve sits higher than the fuel pump.
