Fuel Vent line from fuel tank
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,463
2,895
173
Florida
My carbed 83 has a vent line that comes off of a valve in the top of the Fuel Tank and goes to the carbon canister in the engine compartment.. Can I remove it or what can I do with it if I remove the carbon canister?
Why do you want to remove it?
The tank needs to vent somewhere, and that canister helps control the fumes.
So everyone has left this canister on and no one has moved this vent line elsewhere??
The vent canister is the only part of the emissions system I left. I have no desire for my garage to smell like gas fumes on a hot day.
There's no reason to delete it. If you don't want to see it, relocate it into the fender and extend the vac lines/wiring.
  • Useful
Reactions: General karthief
The "pollution" devices on this 83 were all vacuum operated and quite a engineering nightmare.. ALL of it will be removed... So no vac lines will be going to the canister.....Will it still work if I keep it with the gas tank vent line?
Code 85 CANP solenoid - The Carbon Canister solenoid is inoperative or missing.
Revised 11 –Jan_2015 to add warning about vacuum leaks due to deteriorated hose or missing caps on vacuum lines when the solenoid is removed.
Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
If you disconnected the carbon canister and failed to properly cap the vacuum line coming from under the upper intake manifold, you will have problems. You will also have problems if the remaining hose coming from under the upper intake manifold or caps for the vacuum line are sucking air.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Connecting the gas tank vent line directly to the intake manifold will result in fuel vapor being constantly sucked into the intake manifold. There is unmetered fuel that the computer cannot adjust for. The result is poor idle and poor fuel economy.
attachments\58191
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
The purge valve solenoid should be available at your local auto parts store.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
I've removed the charcoal canister on a few cars I've owned over the years and never had any ill effect but some have noticed a fuel smell. If you remove the canister just keep it incase you want to toss it back on in the future. You can leave the line open or put a filter over it.
attachments\58191
Carbon Canister:
Thankyou jrichker for the response... The car is an 83 so no computer or FI... As I said the engineering nightmare ( pre computer) of vacuum hoses and lines will all be gone...... If I keep the canister and the tank vent line I assume that would be OK?? Again there will be NO vacuum line to the canister, I ASSUME creating a draw for the tank gas fumes.....
The factory five cobra guys simple make a charcoal canister out of a garden sprinkler head, activated charcoal and run the vent line to that any mount it high inside the fender.
when you start noticing fumes, change out the charcoal.
Reactions: limp
