vents stopped blowing. bad blower motor???
  • Thread starter Thread starter stykthyn
  • Start date Start date May 1, 2008
stykthyn
5,232
2,652
223
gainesville
May 1, 2008
  • May 1, 2008
I was driving my 93 home today and the vents stopped blowing air. I thought maybe a vacuum hose might have come loose, but there is no air coming out of anywhere and all the hoses are still attached? Is the blower motor toast? what do i need to check first? If it is bad how much of a PITA is it to replace???
Fett
766
  • May 1, 2008
Did you check every speed? Blower motor resistors are a common break, if the resistor fails the blower will only work on high. So try the high setting and see if you get anything...if it works on high, then it's the resistor.
If not, first check fuses, then use a multimeter on the blower to see if you are getting power to it. If you are, then the blower motor is dead...if no power, start checking wires.
Fett
766
  • May 1, 2008
If not, first check fuses, then use a multimeter on the blower to see if you are getting power to it. If you are, then the blower motor is dead...if no power, start checking other electrical components. Switch first, then wires and fuses.
stykthyn
5,232
2,652
223
gainesville
May 1, 2008
  • May 1, 2008
doesnt work on any speed. going to suck not having defrost in the morning to defog my windows.
where is the blower motor anyway? I am not even sure where it is. do I have to take the dash apart to find it?
L
Lunch Box
40
NY, Long Island, Elmont
May 2, 2008
  • May 2, 2008
think you can just take a 12v test light to the Fuse in the panel for the motor if hte test light goes on then its the motor
if not...
as stated start checking wires
i have to do this my self and itd be great if somone could back my post up or correct it
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
E
Noise near blower motor behind dash?
  • Ethereal_Zer0
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Ethereal_Zer0
E
9
1998 V6 - What is this line called?
  • 98_Stanger
  • Aug 10, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 10, 2025
nickyb
