Vert Bracket
torri834
Well I had my first problem this weekend. I only got the car on 05/05. One of the brackets to hold the top on snapped this weekend. I took it back to the shop and they don't have the part so they had to order a replacement. Sorry if this is a repost I couldn't find anything. :fuss:
Has anyone else seen this problem?
I got this from my salesman... is this the bracket you broke?
Hello Ken,
Hope all is well with you and yours. The following came through my Ford dealer page and I thought you'd be interested in seeing it.
Continued enjoyment with your Mustang.
Thanks again,
Allan
To: All Ford Dealers
Subject: Mustang Convertible Top Raise/Lower Instructions
The convertible top latching mechanism on the 2005 Mustang is significantly different from what has been used in the past. Some convertible top latch handles have broken due to excessive force applied when closing the top.
Convertible owners may have difficulty in latching the top, or risk breaking the lever, if they are not aware of the unique operating characteristics of the new latch design. It is critical that you communicate to customers the proper way to raise and lower the convertible top. The correct instructions are below.
INSTRUCTIONS FOR LOWERING THE CONVERTIBLE TOP
1) Bring the vehicle to a complete stop and leave the engine running to avoid draining the battery. Engage the parking brake. (Note: The convertible top will not operate unless the vehicle is traveling less than 1.8MPH (3km/h).)
2) Check the top stowage compartment behind the rear seat to make sure it is empty, then check the top outer surface to make sure it is dry and free of leaves and debris.
3) Unclamp the top from the windshield header by pulling each latch handle down, then rotating them toward the back of the vehicle until they are in the full open position and clear the header.
IMPORTANT!! The latch handles must be pulled downwards fully to allow the latch to fully rotate into the open position.
4) If the top has not been lowered for some time, gently push the front edge of the top up to make sure it is not sticking to the header. If it is sticking, this will usually free it.
5) The convertible top switch is located in the overhead console. Push and hold the switch until the windows are down and the top is fully lowered and stowed.
INSTRUCTIONS FOR RAISING THE CONVERTIBLE TOP
2) Open the Driver and Passenger side latch handles by pulling them down, then rotating them toward the back of the vehicle until they are in the full open position.
3) Push and hold the convertible top switch until the windows lower completely (if up) and the top unfolds and moves forward toward the windshield header.
4) Continue to hold the convertible top switch to raise the top until it has reached the fully closed position, flush with the header.
5) The two pins under the forward top edge should align themselves in the matching header holes when latching the top. If they do not, use the center grip located above the rearview mirror to pull the top down and the pins into position. DO NOT apply excessive force on the latch handles to bring pins into position, as this may cause them to break.
6) Secure the Driver side latch first, followed by Passenger side. Pull down on the latch handles, then rotate them forward into the windshield header until they reach the full forward position. Flip to latch handles up to final position so that they are flush with the windshield header.
IMPORTANT!! The latch handles must be pulled downwards fully to allow the latch to fully rotate into the closed position
Yup. The driver's side roller was broken upon delivery and noted at that time. It was broken but attached due to the tape so it was not missing. The dealer replaced the part and adjusted the top to allign it better to the front window.
