Almost center mass under each seat cushion is a tab. Use a small flat head screwdriver and push in on the tab, while holding the tab in, use your other hand to grab the front of the seat right where the tab is, and pull up. Do this on both sides. If you lightly pry up on the seat cushion, you can see this tab, a white vinyl piece. Be sure to push the seat belt buckles through the seat to remove it. It pops back in when you install it, just seat the cushions in the rear and push down on the front.
