had the same issue, take out the 2 screws holding the driver's side switch panel to the actual rocker switches (under the drro handle/ door pull thing).. there are little copper connections that are made when you hit the window switches. I used a small pick and some wd-40 and cleaned all the contact points of the switches. Then tried my best to throw some dielectric grease in there to prolong any further corrosion/issues. All window switched work great now.
Initially, mine were so bad the rears didn't work at all and you had to fight with the fronts. I guess with water/dust/crap getting in the switches from the top being down makes them more prone to getting corroded
