VERY BAD BELT PROBLEM
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Mar 5, 2008
mustangfan1990
505
Lenoir, North Carolina
Mar 5, 2008
  • Mar 5, 2008
I have a very bad belt squeal. A guy told me he thought it was my supercharger belt and to loosen my tensioner and I did and the squeal is still there. It sounds like it is coming from the power steering pump. It is VERY LOUD and only goes away at idle or below 1000 rpms and as soon as it hits 1000 or higher it comes back. This is a very annoying problem. It does look like the power steering pump is alittle unaligned with the belt but just alittle. There was a little belt chirping before I put this supercharger on but you could barely hear it once the car got warmed up. Now it is loud all the time. Also it look like there is smoke coming out from underneath the car where the tranny meet the motor. Could I have blown out my rear main seal when it was making boost?
mustangfan1990
505
Mar 5, 2008
  • Mar 5, 2008
I was just looking at the belt and from where it runs to the smog pump to the power steering pump looks like the power steering pump is set back a little from the smog pump. It also looks like the power steering is cockeyed a little how would I fix this? I have the a/c delete kit which mounts the power steering up where the a/c use to sit. I dont see how the P/S would have adjustment.
NKau
1,346
Jefferson, WI
Mar 5, 2008
  • Mar 5, 2008
You need to isolate WHERE the sound is coming from. Nobody can listen to it for you. The most common things I can think to check would be the smog pump itself, and the tensioner pulley. Your power steering pump could be going, but typically won't make a screeching like you describe.
mustangfan1990
505
Mar 5, 2008
  • Mar 5, 2008
well it is at the power steering. If you look straight down the belt it is straight until you get to the power steering pump and then it is cockeyed a little, but I down know how I would fix that
NKau
1,346
Jefferson, WI
Mar 5, 2008
  • Mar 5, 2008
Put shims between the bracket and the pump
mustangfan1990
505
Mar 5, 2008
  • Mar 5, 2008
Yeah I thought of that but the way that kit is made is it has 2 bolts on the left side of the pump ( the two mounting holes for the pump) it would work good if it had one on each side or two on each side. I will try shimming it to at least get the belt in the center on the pump but i dont see how that would straighten the pump
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
D
Engine Serpentine belt squeal after reinstall?
  • dqureshi06
  • Oct 30, 2024
Fox 5.0 Mustang Tech Nov 1, 2024
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
