Vibrating after changing u-joints
Jan 4, 2019
Port Charlotte, FL
Changed the u-joints in my 02 v6 mustang and now it vibrates really bad. Cant even drive it because I'm scared it's going to mess something else up. Please help
92
17
18
E. TN
You may have had a needle roller lay down when installing the caps. Get all the new bearings standing up and in place, then fill the caps with your favorite grease to hold them in place during assembly. The joint should work smoothly in the yokes when assembled.
wmburns
SN Certified Technician
Aug 14, 2009
4,899
348
154
Houston Texas
Did you match mark the drive shaft before removing from the pinion flange?
Are you POSITIVE that the yoke is fully seated onto the pinion flange?
Did you drop or bump the drive shaft while it was out?
Does the U-joint move freely inside the yoke?
Jan 4, 2019
Port Charlotte, FL
I took them back out and re did it. The vibration seems to have stopped however something still doesn't feel right
Neuron
Mustang Master
Nov 6, 2016
731
141
83
69
