  • SN95 4.6L Mustang Tech
vibration @ 65mph?
  • Thread starter Thread starter steedastang99
  • Start date Start date May 27, 2004
steedastang99
67
  • May 27, 2004
I'm getting a vibration in my steering wheel and my pedals at 60 to 70 mph. I had my tires balanced and it didn't seem to help. The weird thing is that somedays its worse then others. I've checked the suspension and eveything is in good shape. I dont think its drivetrain related because I do have an aluminum drive shaft. My car is realy starting to pi$$ me off, it seems like every time I fix one problem something else happens.
XTONKAX
619
UT
May 27, 2004
  • May 27, 2004
Rotors would be my next guess.
steedastang99
67
  • May 27, 2004
I just had them turned, I was getting a shake when I applied the brakes. That problem is fixed but the vibration at speed is still there....
340.29m/s
213
Blue Springs, Mo
May 27, 2004
  • May 27, 2004
So it vibrates even when you are not on the brakes...
and also, is it only right around 65 or if you go even faster does it get worse?
pony_vert02
285
AUSTIN,TX
May 27, 2004
  • May 27, 2004
could also be alignment problem.. vibration at speed ( steering column) is usually one or the other..
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 27, 2004
  • May 27, 2004
U JOINT
J
johnnyboy1111
84
  • May 27, 2004
vibrate
sounds like the tires....some times a tire doesnt take a balance or its done wrong or theres a belt shifted in the radial that you cant see....switch backs to fronts make sure the pressure is correct,try 35bs and reduce it 2 lbs and get back to the speed where you feel the problem...if the wheels are tight when you try shaking them when its up on a jack.....check the stabilizer & bushings.....even new tires can cause trouble.........................Johnny
KaPPaBaLL
1,326
BAYAREA
May 27, 2004
  • May 27, 2004
alignment man
steedastang99
67
  • May 27, 2004
I did just get new tires and the problem started not long after that. I'm going to take it back to where I got the tires and see what they come up with. thanks for the advise.
Ryan02Stang
1,181
Arlington Heights, Illinois
May 27, 2004
#10
  • May 27, 2004
  • #10
Its most likely your tires...I would go get them rebalanced.
pony_vert02
285
AUSTIN,TX
May 27, 2004
#11
  • May 27, 2004
  • #11
BTW, what tires did you get?? Try going to Discount Tire to have them balanced.. they have this phenomenal tire/wheel balancing system called the Hunter 9000 or something like that.. the machine balances the tire AND the wheel...
68 & 00 GT
2,407
HOUSTON TEXAS
May 27, 2004
#12
  • May 27, 2004
  • #12
how many times have you had your rotors turned ? If they are too thin it could caue them to not dissapate heat properly and cause that.
My car pulls to the left when I really get into the gas. Stupid stuff like that is very aggravating.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
