Vibration damper questions.....
  • Thread starter Thread starter 93 LX
  • Start date Start date Jan 1, 2006
93 LX
3,081
Norwalk, CA.
Jan 1, 2006
  • Jan 1, 2006
This morning I started my 93 LX 5.0L stang anf lo and behold, a huge vibration. I shut her down and looked under the hood. What I saw was the weight of the Vibration damper was against the front cover and the shiney hub of the damper still attached to the crank.
My question is how do I remove the entire unit. I have a Vibration damper removal tool but if I remember correctly this attaches to the weight part of the unit. I am assuming that this will remove the weight but once removed how do I remove the hub part of the unit? Do I use a gear puller type tool? Any one run in to this issue?
HELP! LOL
Allen
P
PRO50SC
1,012
Olney, Maryland
Jan 1, 2006
  • Jan 1, 2006
Yes, you need a puller.
93 LX
3,081
Norwalk, CA.
Jan 1, 2006
  • Jan 1, 2006
Yes, I know but when the weight of the damper comes off how do I remove the hub of the damper. The unit it not one piece and mine has seperated. The damper removal tool screws in to the weight and assuming its still one piece the whole unit slides off the crank snout. With the unit in 2 pieces the weight will slide off but the hub will remain on the snout.
How do you remove the hub part on the snout.
Allen
HISSIN50
34
129
Jan 1, 2006
  • Jan 1, 2006
I hate to say that I almost wonder if you would need to use a jawed puller on that. I have not done one like that so I dont know of a known easy method though.
Good luck.
Dbeck002
710
South florida
Jan 1, 2006
  • Jan 1, 2006
HELP! LOL
Allen
The puller should attach to the inner section of the damper. Go back and look, im pretty sure the inner hub is what is being pulled on.
P
PRO50SC
1,012
Olney, Maryland
Jan 1, 2006
  • Jan 1, 2006
Allen
There arte bolt holes in the hub of the crank where the pulley bolts to. That is where you attatch the puller.
This will work but not what I'm talking about....
http://buy1.snapon.com/catalog/item...group_ID=11920&store=snapon-store&dir=catalog
This one, see the triangular shaped piece in the middle, the bolts go through there and attatch to the hub, the rest is pretty self explanitory.
http://buy1.snapon.com/catalog/item...&group_ID=1243&store=snapon-store&dir=catalog
P
PRO50SC
1,012
Olney, Maryland
Jan 1, 2006
  • Jan 1, 2006
See how there are bolt holes. They bolt to the hub. (balancer) That it where the puller bolts screw to. Below
93 LX
3,081
Norwalk, CA.
Jan 1, 2006
  • Jan 1, 2006
COOL,
I have not done it in quite some time so my memory may be a bit foggy. Maybe all the Tequila I had at my Graduation party a few weekends ago may have killed those memory cells! LOL
Anyway I need to get a new damper so I will get this done next weekend and let you know how it went!
Thanks and I hope your New Year will be safe and a good one!
Drive it like you stole it!
Allen
P
PRO50SC
1,012
Olney, Maryland
Jan 1, 2006
  • Jan 1, 2006
93 LX said:
COOL,
Allen
NP man, good luck!!
Transmission Damper
  • welder4956
  • Jan 23, 2025
1974 - 1978 Mustang II Talk & Tech Feb 3, 2025
welder4956
  • dan50
  • Jul 18, 2026
dan50
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
